Xtant 604x
Ok, I've replaced all the parts I found to be bad in the first channel. Both the dc offset and the bias pots appear to work as they should, it's not burning any resistors. So it looks like possible I know what I need to do to finish the other 3 channels. However, I did notice that the 530's seem to run a bit warmer than the 9z34's. Is that normal in this amp?
OK, I thought they should run about the same temperature. I'm not sure what is causing the 530's to warm up more, the rial is pretty centered on +/-27 volts. I would imagine that where ever the power is going should be warming up a component or components shouldn't it? To get the dc offset near 0 the pot had to be turned up higher than I expected.
