got one on the bench and need some insight. all 3 channels read 5.3vdc or more and the amp only draws 0.6amps at idle with no fault lights on. amp has never been touched and the rail voltages are a bit high but they're stable. any suggestions?
What did you mean when you stated that the rail voltage was high?
Do you have both positive and negative regulated voltages on the op-amps?
