Xtant 1001d
Does anybody know the value of R172 on this amplifier? I can tell it’s part of the pwm circuit for the gate drive. I think it’s a 10 ohm resistor but when I replace it I get the powersupply to operate and rail to rail oscillation on outputs then the resistor instantly starts smoking and separates. I pulled the buffer transistors and irf44’s to confirm they are not shorted and even replaced the 9942 out of a working amp to confirm they aren’t bad. A schematic would be better but I know there probably isn’t one. I took out the rectifiers also to separate the powersupply from output section and R172 still smokes.
Here is an image
Yes, it’s in series with the postive terminal of the cap and feeds a pair of 1k ohm resistors that connect to the buffer transistors. It appears like this circuitry is used to feed the pwm to the 9942 driver IC’s but I checked everything outside of the board with a transistor tester and dmm and it was good.
