Xs6600 Emitter resistors
I'm going through the resistors in my Xs6600 and noticed the emitter resistors on my right sub channel are different than all other emitter resistors in the amp.
The left sub channel matches the rest of the channel's (4, .22-Ohm resistors)
Left sub channel
However the right sub channel has different value resistors (4, 2.0 resistors)
I am wondering if this is normal?
You’ll need a precise meter to read that low, if in doubt just replace them I believe extreme heat might have changed the color of the bands. They probably still read within tolerance but best bet is to replace them.
