XRK Audio Etsy Store
Founder of XSA-Labs
Joined 2012
This is a thread to make announcements and highlight new products that will be coming out in my shop on Etsy.
Here is the link to the store:
https://www.etsy.com/shop/XRKAudio
Products to highlight as of May 3, 2023 are:
RTR BTSB with Tube Buffer - HypeSET (preorder):
https://www.etsy.com/listing/147415...499&click_sum=cca02e94&ref=shop_home_active_1
RTR BTSB Panel Mount buffer:
https://www.etsy.com/listing/137689...619&click_sum=dd1364a2&ref=shop_home_active_2
RTR SSR Speaker Protection:
https://www.etsy.com/listing/932716...41&click_sum=483bacd9&ref=shop_home_active_15
RTR TPA3255 Class D amplifier:
https://www.etsy.com/listing/755264...34&click_sum=c1251dcf&ref=shop_home_active_24
And I will soon add pre-orders for the HyperSET - a BTSB with a SE triode tube buffer and volume control - please stay tuned.
Reactions: 4 users
Founder of XSA-Labs
Joined 2012
Yes, thanks for reminding me. I’ll add that to the shop soon.
The HyperSET tube buffer BTSB is now up for preorders.
Founder of XSA-Labs
Joined 2012
I use silicone insulation wire so it’s quite soft and the strands are fine and soft. I twist by hand starting at one end and passing the wires through my thumb and index finger to keep them flat (2 or 3 parallel array) as they feed through. Try to make sure all wires receive equal twist rather than one wrapping itself around one that is essential a straight shot. The other hand does the twisting. There’s definitely some practice and technique involved but the soft wires help a lot.
I use 28ga silicone wire like this for small signal stuff like preamps and headphone amps.
https://a.co/d/cPIKHlf
Reactions: 1 user
Joined 2021
Thank you for the tips!
I think I have a patience issue with that type of things. I saw people do it with drills as well, but that didn’t work for me either.
I’ll try that wire.
