Hi.
I am running Windows XP SP2 with Panda AV Platinum - all up to date.
Panda has reported 2 incidents of W32/DMSPatch.A.
Both appear to be registry entries pointing to this file :-
c\windows\system32\dmserver.dll
After a scan, Panda puts the virus on report but does nothing else.
During use, the virus is intercepted by Panda (red info box in corner) and says it has been neutralised and quarentined. However, the file is still there and nothing appears in quarentine.
I cannot rename the file, delete it or anything else even though 1 site suggests replacing with a clean copy.
Panda website states that it should delete the file!
Anyone come across this ??
Anyone suggest anything (oher than get a Mac!)
Andy
Andy
kelticwizard said:Boot into Safe Mode and try to delete it then?
Just a suggestion-sometimes it works.
Keep tapping F8 as soon as your machine comes on. That takes you to Safe Mode.
Yep. Tried that !
I also tried going to the dos prompt and tried to reset the attributes/delete/rename. All I get is access denied.
Andy
There are a lot of good computer people on here, but here are two sites which specialize in this sort of thing where I have gone successfully in the past.
aumha.net I have gone to many times. I am amazed at the lengths the people at aumha have gone to to help-realy detailed, step-by-step advice.
Castle Cops I have gone to only twice, but was quite pleased with the response.
www.aumha.net
www.castlcops.com
www.aumha.net
www.castlcops.com
Is there a program in the add/remove programs list called Comet Cursor? If so, try uninstalling it.
http://www.pctoday.com/editorial/ar...es/2005/w1602/31w03.asp&ArticleID=25525&guid=
there is a spray you can buy
you spray the pc outside
this will keep the virus away from your computer
Spybot Search & Destroy is a very good free program.
It is welknown.
Will search your PC and give you info and options to 'clean up'
http://www.spybot.com/
It is welknown.
If the contents of an executable file, in this case a dll, are loaded in memory, the file gets locked by Win XP. When you open a DOS session in Win XP that is only emulation, since XP, unlike Windows 95 and 98, is not DOS based. To remove the offending file you need to boot the machine using MS DOS, DR DOS, or other OS that understands FAT32. That OS should be loaded from a diskette or USB device, if the BIOS on your board supports it.
Yes, Grimberg is correct.
You need to Boot to any recent version of DOS (I think 6.22 is latest)... I assumed you were booting to DOS. That access denied didn't sound right, as there should not be any accessibility issues with that file when booting into DOS.
Find and download a Win 95, 98 or Win ME boot disk. Boot to that DOS disk.
Then find your way to the file and delete, rename, or replace with a know good file and your set.
Problem Solved - I Hope !!!
Hi All,
Thanks for the help.
I had also come to the conclusion that I would have to boot to DOS . The only problem being that at the moment I am on a survey ship in the middle of the Indian Ocean and all the computers onboard are RedHat , WinXP or worse Vista !!
So I had to download a Win98SE image and burn a floppy.
Having done that and booted to C:\ , I was able to rename the offending file and replace with a clean version.
I am scanning as I write and so far all is well.
Thanks again
Andy
Hi All,
Thanks again
Andy
XP Virus
Hi Andy
Congrats Triumph over evil (with a little help from our friends). I run the same setup and same Panda antivir.
Spam has onbly been a very occasional problem but the last two weeks, developed into a veritable flood. At first, I hoped it would stop but it didn't. So, abvout a week ago. I started forwarding each one to my service provider (who can barely keep up with blacklist confirmations).
Anyway, I'm glad to reasd your prob's are no more. Happy festivities and a perfect 2009 to you and all diy'ers
bulgin
Hi Andy
bulgin
- General Interest
- Everything Else
- Xp Virus - Help Appreciated
