Oh. I saw that the buffalo III costs about 300eur..That is way to much for me to spend on a dac. I think I should go with waveIO v2 + ES9023 subbu dac.
Do I need to only connect them over I2s and that's it or do I need to configure or program something on the boards?
And could I connect maybe a adc for a Mic also to the WaveIO through I2s or is this impossible?
thank you in advance. I am still on time with the subbu dac group buy..
only need to wait for the improved waveIO..
Greetings and happy listening....
Hi, I see that this device has onboard X-tal oscillators being able to provide MCLK for an extrenal DAC;
but my question is, could this device be configured as a slave to an existing performant master clock that is placed near an external DAC so that this external clock provides the 11.2896 Mhz to the board, actually slaving to it the board and the transport (the PC)?
In affirmative case does one need to remove the existing XO from the board and connect the external clock in the same place, or is there a connection pin available and a jumper that could bypass the already mounted XO?
Thanks.
Thanks.
Hello rondadon! Thing could be confusing here if you are speaking about WaveIO rev2 board so let's put it this way: WaveIO rev2.0 (or WaveIO next revision - without any specific number) will have to wait to show up and as I can see my schedule, I'm strongly sure that it will pass more than "little bit" (no offense!) to show up. SO, let's exclude it for now.hi there. Tanks For your answer. I can wait a little bit. Is there a releasedate available for the rev2 board?
will it be much more expensive then the current revision?
There are two chances for you:
1. is to buy actual WaveIO offer and wait for the daughter card to show up to improve its functionality or
2. wait (hopefully a little bit 🙂 ) for the daughter card to show up and take them as a bundle.
I personally prefer to choose what is *real* so option 1 would be a good start for you. As a side note: you could also add DB to your WaveIO card later on... that's what all peoples from that list are waiting for (- with few exceptions), just need to place your name there to take the benefit of this GB.
Forgot to say: this WaveIO card is for playback only so you cannot add ADCs to it.
No ideas, just plans 🙂And is there any Idea to make the waveIO 6channel compatible? eventually with an extension board? This would be awesome...
Thanks.
It's one of the DBs functionality (and my future task). Wait for it please.
Kind regards,
L
thanks for your quick answer, then I'll wait for option nr. 2, so I could buy the actual board + DB together as a bundle
Kind regards,
L
Thank you for your answer.
So you say that the "next revision" waveIO would be the current board with the daughter board in one "delivery" . So all those who had ordered or who have the current waveIO Board til now will get this daughter board and there will be NO difference to the "next revision" waveIO Board?!
Or are you planing to change something directly on the waveIO board for the next revision?
If there will be no difference between the current version with daughter board and the "next revision" then I think It would be the best to order now!
Thank you in advance!
Kind regards
Ron
Lucian,
Can i use the i2s and the the spidf output at the same time for testing two dacs?
I want to make listening session between a Pass D1 Clone (from Spencer) and my mojo2.
@ Luxury54:
List is updated:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
42. 43. 44. 45. Mats x 4
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
62. & 63. Claudius J. x2
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
Kind regards,
L
List is updated:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
For the moment WaveIO is sold as is and later on with daughter card when it will be available. This bundle will exist as long as the new WaveIO is in development and will reach end of life after that. There will be some differences between the two WaveIO boards but the output stages will be identical.Thank you for your answer.
Kind regards
Ron
Yes you can, enjoy 🙂Lucian,
Kind regards,
L
Please add me to list
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
Kind regards,
L
Thank You for the clarification...
I think I can wait til the end of the year for the new waveIO board (revision 2)! Or will it take much more time to complete the board.
Can you estimate maybe how long it would take til you will have the new board ready?
Are there any plans to make the WaveIO maybe modular expendable with Add-On Boards.
So say if you want more channels or if you want also ADC or something else you could buy a extension board for your wanted purpose and plug it into the WaveIO Master Board.
This is only a idea which had come to my mind which would be really awesome and would fit much more people's need and will also make this board more popular.
Thank you very much for clarification. 😱
Greetings from germany!
Please add me Lucian
I have also a question : I would like to test several PC configuration simultaneously (eg one Linux mpdpup, another Linux Vortexbox, one Windows PC. Is it possible to set a switch in the USB port ?
Similarily, I would like to be able to switch between several PSUs (USB fed, external 1, possibly external 2). Is it possible and without danger to the WaveIO card ? I guess it may be easy for USB pwr/ ext 1 PSU with the power selction header, but maybe more tricky if I want to compare ext 1 PSU and ext 2 PSU.
BR
Jean-Louis
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. JLOP
BR
Jean-Louis
Li-Po Battery Power Supply
Has anyone tried powering their WaveIO with a Li-Po 5V battery such as those supplied to charge mobile phones, like this one -
Anker® Astro2 Dual USB Output 8400mAh Backup External: Amazon.co.uk: Computers & Accessories
I would cut off a USB cable to feed theWaveIO screw terminals.
Seems to be a very cheap way of testing it out and plenty of current reserve to power it for a few hours.
Those batteries have charging and step up circuit inside. Noise and not suitable for audio.
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. JLOP
73. Stixx
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. JLOP
73. Stixx
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. JLOP
73. Stixx
74. CeeVee
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. JLOP
73. Stixx
74. CeeVee
what happened
What happened to post #1369?
I wa s on the list and I was dropped.
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stix
75. CeeVee
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stix
75. CeeVee
@ mjock3: I apologies for this... I'm outside my country for a week and I can't track all the changes on this thread as my internet connection and time devoted for it are rather limited: some personal matters to solve... Anyway, this is not an excuse thus I've made some time to change the list accordingly (now I saw that is the same as yours 🙂 ). Here it is:
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stixx
75. CeeVee
The other questions will be answered when I will be back.
Thank you for understanding,
L
1. hirez69
2. analog_sa
3. m.massimo
4. ozlegend
5. luisbock
6. vitalica
7. palmito
8. gabanyayaya
9. danny_66
10. shoom
11.12. kp93300 X 2
13. lindamar
14. merlin el mago
15. Reo
16. arkadiush1
17. jmltinc
18. zibra
19. tagheuer
20. hochopeper
21. hacker
22. Bemused
23. vanwykca
24. sandor
25. jrling
26. bismuth
27. necplusultra
28. flocchini
29. ichiban
30. edbk
31. Nikon1975
32. pawlus
33. dubai2000
34. henri47
35. presapian
36. Corpius
37. Ryssen
38. carsten.witt
39. Sidiropa
40. Ryelands
41. krautxy
46. ecchecequa
47. 48. lm1no2 x 2
49. Magsy
50. Jogi
51. CKL
52. needsp
53. number9
54. steve jones
55. nuriasanta
56. miksi
57. audiodesign
58. hordmop
59. cjunkk
60. Thermio
61. dex-rex
64. boggy62
65. sck2288
66. rjbaldwin
67. ravid
68. igor
69. neugruen
70. Miclaud
71. Luxury54
72. mjock3
73. JLOP
74. Stixx
75. CeeVee
L
Sorry Mjock3, It is probably me, I did not intend to steal your option on the mystery cardWhat happened to post #1369?
Lucian, maybe an attached file would be more convenient as the list is growing steadily ?
BR
Battery Power
Good point.
However, surely if one disconnected the device from the mains when playing the WaveIO with it, the charger circuit would not be energised and therefore would not contribute noise?
Also if using the 5V output, would that involve any step-up device being active?
Do you have a better suggestion for Li-Po battery power that is convenient to use?
Many thanks
Jonathan
Good point.
Many thanks
Jonathan
- Digital Line Level
- XMOS-based Asynchronous USB to I2S interface
