XL6009 board does not start with load
I'm trying to get this tiny XL6009 board working with 35 Volt DC output and a default load of 35 mA with 9.5 Volt DC input from a wall wart.
When I power the the wall wart I get 35 Volt DC. I can change the voltage if I want, so the XL6009 board is working. When I connect a 35 mA load I still get 35 mA. Still good!
But when I power the wall wart with the load already connected I get an oscillating output voltage my DMM cannot follow, from 4 to 15 Volt (very unstable).
The wall wart gives 9.5 Volt DC all the time, so the input voltage is stable.
Is there anything I can do to get the XL6009 board running with a load already connected?
Regards, Gerrit
Hi Bohrok2610,
I guess this could be the reason. I will definitely try with another wall wart.
As I had several XL6009 boards lying around I took a "fresh" one. Same issue as the other two I tried.
I solved this by adding a 6.8 Ohm resistor in series with the + lead of the wall wart to the XL6009 board and a 22000 uF capacitor after the series resistor (palallel with the board's input).
This was done with my trial and error method, and the result is now a 100% output stable voltage and the XL6009 board is starting with my default load (only 25mA).
Regards, Gerrit
