I have been looking at the very long threads on mods for DCX 2496. There has been some very impressive work!
My interest is restricted to bypassing the op-amps & electrolytics at the output (after the DAC) only. Rather than upgrading the op-amps and using fancy caps, I am simply interested in using a transformer after the DAC.
In my case, each transformer should be in the $5-15 range (perhaps an edcor) and could be chosen to provide the the low pass filtering also (the anti-aliasing). I assume this could provide much of the benefit (I would be using a digital in & would not be using the unit's ADC).
Unless I am ignoring something, this could be an affordable alternative that others might like to try also.
Thanks in advance,
-Tom
Thanks in advance,
-Tom
