For Sale XA252 PoP R1
Things you have for sale.
@schultzsch
I finally connected the modules for testing and with both connected my PSU sink to +/-22.6V, so I re-biased to 1.4A. Measured across the two 0R22 (0R11) resistors for 154mA which gives 1.4A. Test heatsink becomes hot fast but that is expected.
One module has 8mV offset but the other one is at 23mV and it is a little high for me, not terrible but I prefer below 10mV offset. I see the offset trimmer is not installed, should I install one?
Do
Reactions: birdbox
Hello Do,
I left out the trimmers for the offset adjustment because when you adjust the offset you alter also the thd profile.
I did the best possible to have under 40mV.
I consider 40-100mV offset ok.
If you insist having the offset under 10mV you could install the trimmers.
This part should be used for this task.
How do you like the sound?
I built one for a friend and it is implemented exactly like that. He loves it a lot.
Recently he sent a photo with the amp together with his Christmas tree.
If everyone is happy then I am happy too.
