X-sim 3d bandpass filter
What is the turn frequency and the bandwidth ?
For example in this picture , in this adjustment what will be actually the cut off of the HPF LPF in this bandpass ?
Do you need to know this? These frequencies can be calculated but then they are combined with your response so it changes. You could look at the -3dB or -6dB points and estimate the slopes.
Even better you can work to a target response.
