Keep your Tannoys if you don't plan on crossing TD4001 at 2-3K to another BE TAD like TD2002 or at least TD 2001. ET703 is too delicate to go that low but would do nicely over TD 2001 in 5way . You will have a hard time with TAD with any serious music but they may be bombastic with rock/pop. Also you will be restricted pretty much to original TAD horn or similar CD design with EQ and heavy resistor padding. They sound unbearable on clean tractrix or other neutral horns. My.02 cents
