For Sale WTT - Jelco heavy brass weight.
Things you have for sale.
This was on a tonearm I picked up. Looking to trade for the stock dampening fluid cap as it's going on a suspended table and this one is much heavier.
I'll look for more info on the piece, essentially the heavier weight has multiple sonic advantages over the stock one.
Please reach out if you're at all interested and I can send more pics and information. Will have to be a trade or help me source the stock piece as you need one or the other.
Here's a brief description and link to one that sold earlier:
Add incredible performance and add the TTW Jelco Brass Dampening Cap. Adding high mass over the pivot dampening screw provides massive dampening to the critical tone arm pivot point.
The solid brass is accurately counter bored to fit precisely over top of the existing little aluminum fluid cap. (See pictures)
The brass is super machined to a gorgeous finish and coated with a special anti oxidant aircraft coating that is a clear coat and requires no polishing and will look brand new forever.
The cap may optional be glued (three drop of crazy glue in side the cap) and place it on top of the existing fluid cap and let sit overnight. The brass cap will now unscrew the fluid cap and also provide additional damping. Blue tack or silicone mat also be used.
https://www.canuckaudiomart.com/det...m-pivot-damper-brass-polished/images/2178849/
