[WTT] Acronman Sony VFET 2SK82 KD-33/KE-33
Joined 2004
I have two 2SK82 from Acronman Electronics, one is grade KD-33 and the other is grade KE-33. I'm looking to trade either of them for one of the other grade (to get a pair of VFETs with the same grade). I measured their Vgs according to the attached schematic. Bonus points if you have a VFET with matching Vgs :)
Edit: I attached the wrong pic. See post #4 for the actual VFETs.
Joined 2004
You're right zeroalbedo, I attached the wrong pic.
The VFETs in question have the following specs:
The KD-33 has a Vgs=-10.50V @ 0.5A Id.
The KE-33 has a Vgs=-9.95V @ 0.5A Id.
@ joshvi: Are you sure there aren't any other specs hidden in the code? Just production date and pinch off voltage (afaik)? That wouldn't be so bad ..
