Greetings,
I was looking for someone to build a CMoy modified to be suitable for low impedance and low sensitivity headphones or another DIY amp that would be suitable. No other requirements (though I'd prefer it use regular batteries like AA or other cells, 9volt would be okay).
Thank you for looking and specifically, these would be for a 7th Generation iPod Classic & Audeze Sine headphones. Headphone specs are below:
Specifications
Style
On-ear, closed-back
Transducer type
Planar Magnetic
Magnetic structure
Fluxor™ magnet array
Phase management
Fazor
Magnet type
Neodymium N50
Diaphragm type
Ultra-thin Uniforce™
Transducer size
80x70 mm
Maximum power handling
1W RMS
Maximum SPL
>130dB
Frequency response
10Hz - 50kHz
THD
<0.2% @ 100dB
Impedance
18 ohms
Sensitivity
97 dB/1mW (at Drum Reference Point)
Minimum power requirement
>100mW
Weight
320g
Specifications
Style
On-ear, closed-back
Transducer type
Planar Magnetic
Magnetic structure
Phase management
Fazor
Magnet type
Neodymium N50
Diaphragm type
Transducer size
80x70 mm
1W RMS
Maximum SPL
>130dB
Frequency response
10Hz - 50kHz
THD
<0.2% @ 100dB
Impedance
18 ohms
Sensitivity
>100mW
Weight
320g
