WTB miro AD1862 DAC
I have a board which has all the SMT devices soldered. Good low noise Nikkohm resistors made for audio has been installed. I can also supply opa1656 iv stage mounted on the dual to single adapter board designed by member Vunce (https://www.diyaudio.com/community/...2s-input-nos-r-2r.354078/page-63#post-6475796). I can also populate the entire board with all the necessary caps if you want. However I do not have the dac chips to supply you.
Reactions: dogears
