I'm putting together a two arm table. On the back side I want to use a Audio Technica ATP-12T tonearm. This came with no cable and the cue lifter was not a part of this design, it's a broadcast arm.
I need a DIN to RCA cable, I believe it's the standard DIN cable that fits a lot of the tonearms out there. Not looking for one sprinkled in fairy dust and diamond encrusted, just a decent quality cable that may have come with a tonearm and was upgraded, so now it's shoved into your closet. LOL
The Jelco tonearm lift is a nice quality piece that would fit right at home on the AT tonearm. I'm not sure if anyone might have one in there parts stash, figured I'd ask. I will machine a bracket to mount it to the tonearm post if I find one.
BillWojo
BillWojo
Hi BillWojo,
If you don't get a response try this website and look at the cables available. This cable is an option Connect Phono Cable - Music Hall or you can make up your own DIN Connectors - DIY Cables and Connectors
Kevin
Kevin
