I've been refreshing the Decware mini radials page waiting to grab a pair (in a non-wacky color), but in the meantime I'd be interested to see if anyone has something similar for sale. WTB a small footprint passive single driver full-range desktop setup with focus on nearfield imaging. DIY is okay if it's based on a well engineered plan set. Also open to desktop amps.
Dan
Dan
I have a last set of µFonkenPlus. Stock drivers by i will give them the preliminary treatments that help ameriolate the few issues with the driver. The ones on the bottom.
dave
dave
Interesting, although too big for the corners of my desk. Maybe more applicable for my living room. What are the dimensions?
What about these? Used but work perfectly.
https://www.google.com/url?sa=t&sou...FjAAegQIBBAC&usg=AOvVaw3zP0DZwEgtH7tY8El8C4KR
CHN-50 is quite good. Sort of a low end A5.2/3.
Tozzi is a less than stellar box, and a larger footprint than than the uFonkenPlus/uMar-KenPlus.
But great value if you need somehting cheap you can assemble with a screwdriver.
dave
dave
Great suggestions, it reminds me that there are kits available from Madisound and PE. Any opinions on these?
Fostex P1000E DIY Kanspea 4" Full Range Speaker Kit - PAIR: Madisound Speaker Components
@planet10 - those dimensions are smaller than they look in the photo. I have to remind myself, it's not actually a loss of desk space, it's just transferring the space 231mm upward.
Another not great box, get the FF105wk. There are some easy tweaks to ameriolate their minor issues. Very similar to FF85wk, better bass, not quite as good from there up.
I have a set in Woden’s Falcon. EnABLed to boot.
A bigger box, i put them in twice the volume as the uFonkenPlus/uMar-KenPlus.
dave
dave
Now I see - you're the uFonken guy! Your PMs seem to be turned off, but I'll contact you through your home page.
Would you like some Monsoon PM-9 or MM-1000 planar magnetics?
Interesting, I played around with planars in my DIY days. Not sure if a 200hz crossover point will play well with my standing desk though. I'd still like to find a 2-way passive setup.
