WTB: Dynaudio D-28 AF Tweeter(s) or reasonable replacement
Hi
MDT-32S is a near drop-in replacement ... the 33 is 2 dB hotter
buy 2 for $75 ea
"There are two very good replament tweeters available with the same 110mm flange size. Both options spec out very similar to the Dynaudio D28/2, with no modification needed to your existing crossover.
Morel MDT32S (same 3 hole mounting pattern, tabs are next to eachother as opposed to on opposite sides of the magnet)
Eton 25SD-1 (4 mounting holes, tabs are on opposite sides of magnet like the Dynaudio) "
*Madisound
