I have an older (70's-ish) Kustom 15" pro woofer that is just sitting around (unless I threw it out). It has a slight voice coil rubbing problem when you press the cone in, but it isn't audible when playing (as far as I know, anyway). Just pointing this out in case you're interested in it...
I am interested in both of those. More in the Kustom cause it is probably a lot cheaper and more of what I am looking for minus the age and voice coil rubbing.
Do you have any pics? Is it cast frame? What is nominal impedance? How is the woofer holding up, esspecially the surround? How much do you want for the Kustom with shipping? My zip code is 01921.
xplod1236 said:I have an Audiobahn alum12q that I'm willing to sell (with or without enclosure).
How much?
