I'm looking for a pair of compression drivers. Don't have to be in perfect shape just work as intended. If you have something to offer please send PM. EU preferred.
Thanks,
Thanks,
ev dh1a 2 inch 185$ and shipping
I can also offer few NOS C3g, D3a Siemens tubes in exchange...
Due to shipping costs EU seems to be only viable option.
Regards,
Regards,
Good question🙂
I already have Beyma 15SP for woofer and Beyma 8m60 for mid so i guess range would be from around 1300Hz to 20000Hz.
Thanks,
Thanks,
You can cross the 8m60 at 5K and use a compression driver from there. If this might be an option for you (for me it would be the only option 😉 ) I'll check what I can find on my shelf.
Since i'm total newbie in CD area could you please explain why cross at 5kHz would be only option? Also i'm guessing you have experience with 8m60 and if i'm right cold you give me some advice how to use it right.
Thanks,
Thanks,
Usually audiophiles believing in mantra that x/o filters are best avoided in this range of frequencies.
Btw, you should calculate the risk involved with buying second hand drive units. If there was something wrong with these, and you are a newbie in these matters, might not be a bad idea to cover yourself.
