Hi, I have a Denefrips Athena passive/active preamp (passive for signal path and active for solenoids. The problem is I want to have my HT go through it... I currently am taking the XLR preouts on my Marantz AV8805a preamp and feed them into one input on the Athena stereo preamp. In order to do this I need to raise the level on the Athena preamp to 38 on the volume (the volume goes from 0-60 with 60 being maxed). if I forget to reduce the volume on the Athena to no higher than 14...it could blow a driver when switched to listen to Roon.
So I was wondering if I inserted a XLR mic gain box between the Marantz and the Athena...would that solve my gain issue?
like this one...
https://www.amazon.com/Cloud-Microp...fos.f5122f16-c3e8-4386-bf32-63e904010ad0&th=1
like this one...
I would put a simple resistor divider attenuator on "Roon" source, and leave the volume control near 38.blow a driver when switched to listen to Roon.
The CloudLifter is for much smaller signal levels and needs a Phantom Power supply to work at all.
