Would A TC9FD Work In 6 Liters Sealed?
I have a bunch of these foam containers saved from my prescription mail order eye drops. Volume is approximately 6 liters. Would these work with the TC9FD?
Currently I'm using them sealed. Would ported be better and if so suggestions
on port dimensions? After a little listening I think I'll try BSC. Thanks for any and all suggestions.
This driver won't give any bass, FS is 125Hz and xmax is 2.5mm, so it's made to be used with a (sub)woofer crossed above 150Hz i think at least. It has been used in line arrays lower, but those have many of them and are very inefficient. But this driver won't give any real bass, even in a horn or a TL
