Finally it is finished: my first gainclone
Both PSU cases made from teak beams, 5mm aluminium front and back,
5mm cast plexi for top and bottom.
Amp cases made of Al rectagular profile with 4mm front and back. the insides slide in. Al 4 cases have stainless steel feet which can be fitted with threaded spikes the spikes are on my to do list.
The pictures:
The pictures:
revell said:the PSU
Does anybody know how to put multiple pictures in one post?
only if you have the pics on a different server.
just press the "img" button above the text area in the post editing page. and put in the URL.
your gainclone:
That is one of the nicest ones i have seen. so clean.
is it a 3886 or a 3875?, and do you think those DIN plugs can provide enough current?
Yes they were giving me problems: the biggest problem was the switching of V+ and V-. Some general advice: use different colors of wire, they make life so much easier.Are they, the same amps that were giving,you problems?
If so how did you fix them?
I also fitted a Velleman DC protection module (made in Belgium ) so I can listen worry free
One last picture (for now) of the insides of the audio part
- Chip Amps
- Wouhouw It is finished
