Worth a try or simply silly?
What I'd hope to achieve is better dispersion, clarity (less "distortion" at higher volume?) and maybe even better/lower bass response...
Bad idea or a possible noticeable improvement to my "center channel"?
Calling it a bad idea might be a little harsh, but neither would I expect a noticeable improvement. Why? Well, the combined impedance of the three will be 6 ohms (assuming that they are individually 4 ohm). This will reduce the overall output for a given volume setting by roughly 2dB. So you will have to turn the volume up a little to get the same output! 🙁
However, as there are three speakers, the individual output by the original center speaker will be reduced by roughly 2dB. 🙂 So there are "swings and roundabouts" as we Brits say. However, do not let that put you off giving it a try. 😉
Note: You could get a more solid improvement if you use 4 speakers instead of 3. Why? Because, if you connect them in serial pairs, then connect the pairs in parallel, the combined resistance remains 4 ohms. So the output level remains the same (for a given volume setting). 🙂 However, the individual output by each speaker is reduced by 6dB. Hence reducing distortion etc. 🙂 Also the power handling is quadrupled. 🙂 BUT... That assumes that the amp has the oomph to drive the array. So you might not get the full benefit in practice. 🙁
Thanks jedaisoul. 🙂
Based on my calculations and the fact that they are quoted at 8ohm nominal (but can dip to 4ohm), I could either end-up with 5.3ohm or 12ohm nominal.
12ohm would probably be the safest option.
This is achieved by having two in series, in parallel with one (view diagram in previous post). 🙂
I only have 3 Domes I'm afraid.
I've had an idea of a low cost (or even no cost) use for your spare speakers: Convert your 5.1 system to 7.1. I.e. Use them as "Surround Back" speakers. There are several ways that you could connect the speakers to your system:
1. The best way would be to obtain a 7.1 receiver/amplifier. Alternatively you might try:
2. Connect the surround back speakers in series with the surround ones. This will present a safe load, but you may need to raise the level of the surround channels by 3dB or so. Or, if you are brave (or foolish) enough...
3. Connect the live leads of the surround back speakers to the live terminals of the respective surround channels, and the negative leads to the live terminal of the center channel. Care: This could do permanent damage to the amp, so act with caution.
