working out Z out for tube with IXYS IXP10M45S plate load
Hi There
I would like some guidance as to how to work out Z out of a tube with its plate load being supplied by the IXP10M45S.
I have read the article at maarten@platenspieler.com and I figure It probably should be MU follower formulas given the output is taken from the anode of the driven tube.
Given the Current regulator does not have the plethora of caps and resistors though, I am wondering if it may be accurate.
I would appreciate any help
Nick
Thanks for the triode datasheet
I will try increasing current.. i find with other tubes that they can sound a bit unpleasant at higher anode currents.. Is that my imagination?
The 180F at 5.1 doesnt sound objectionable at this point but i will double the current and see for myself
Once agin thanks for the datasheet.
Nick
I am always confused
Hi EC
dont worry.. i sppend much of my life in a confused state these days as I find it helps with the vagaries of modern life. Thanks to all for your help.
I plan to construct an riaa stage based on the e180f in triode mode and the ixys current regulator..
Will see how it works.
Nick
