Work of Art Thread
The recent art of gaincloning.😉
Parts cost per channel:
IC $7
2 resistors
one coupling cap 4,7u
2 x 1000u/50 PS caps
one potentiometer
Power transformer $60-80 (for new)
8 discreet dides
Plus hardware and casing. You can use cheap parts and your cost may be less than $50, but then, don't expect the greatest sound.
With so few parts it makes sense to use best parts for the job. So I'm using Black Gates which set me almost $100 and Rikken resistors (which seem to be a good sonic match to the rest of the circuit). I'm using oversized 400VA transformer and good rectifiers. But I suspect that the key to the great sound is proper chassiss.😉
here is my near-complete battery powered cd power supply. (dress rehearsal for the pre-amp power supply)
the VU meter isnt hooked up, but it will monitor voltage for the batteries, making sure it never dips too low. wall-wart transformer feeds into a dpst switch that basically steers the power either to the relay bank, or to the charger. in the "off position", power goes to the charger, thus charging batteries, hooked up in parallel. this charges them all at 12v. when the switch is "on", the transformer powers the relays, thus making the batteries a series, at 36v, which is the voltage the cd player needs, thus playing the cd player.
for me this is a big accomplishment. it works well, you flip the switch, relays switch over, and you go from 36V down to 12V, and charging starts. as soon as its all finished, it kicks off, and maintains the charge. once switched on, charger goes off and the cd player is fed with 36V and starts right up.
This old Beauty is a family peace from around 1959.
Of course it's no my work, but Philips's.
But the restoration took several weeks and that's why I'm proud of it.
You should hear it…
:hbeat:
EC8010 said:
Yes, but what is it? Does it sound better than it looks? And yes, you can be sent to hell for covering up the glow.
The full story on my 5-Buck Amp (named by Allen Wright). This amp is sentimental because it represents my 1st tube amp -- twice -- it is based on the amp that came in the fold-down record player my parents bought when i was just getting into my teens and is the 1st tube amp i built on my own -- Allen helped me & i was going thru my 1st read of Jone's book.
It is a single 50EH5 with about 1.4 w running in pentode. It sounds OK -- somewhat limited on the extremes as you would expect from the massive OPTs.
dave
