Woofer with high Qms
Woofer low freqency design is based on Qts, which is the combination of Qes and Qms. There are an infinite number of combinations of Qes and Qms that will give you the same Qts. High Qms happens when non-conductive formers are used. and it is an inverse measure of losses in the suspension. High Qms means low losses and low Qms means high losses...
The only effect on bass frequencies according to modelling is that drivers with higher Qms have higher Impedance peaks - which does not matter for solid state amps and matters only some for tube amps......
Contrary to what others have said, I believe the golden eared crowd tend to favor High Qms drivers because they have less damping and they believe they sound more dynamic. I think that because high enders are the ones more likely to use tube amps nowadays, they are hearing the FR bumps caused by their amps' high output impedance, and they like it. 😉
For what it's worth, I have heard a number of respected speaker designers state that they prefer high QMS designs with low QES. They theorise that there is more dampening occuring within the suspension.
A high BL factor is also a consideration.
Listening to a driver is the final determining factor as figures can only tell you so much (but they are a good starting point).
Qms is related to the dampening in the suspension. A High Qms means low damping in the suspension relative to the mass.
Qes is related to the dampening in the motor system - which is related to Bl/Re. High Bl factor in itself means absolutely nothing at all.
Do a search for Joachim Gerhard of Audio Physik.
http://www.speakerbuilding.com/content/1039/
He is the only "well respected designer" that I know of that has spoken out about this parameter that I know of - and he makes comments that completely contradict what you say regarding the amount of damping in the suspension. He also makes comments that contradict himself. Q is a measure of energy stored divided by energy dissipated, meaning that higher Q means more energy storage 😉 "Dissipated energy" is loss.
.words of JG...
Later, in the 80's, manufacturers started to add more mass, they added more damping, and they made surrounds with high loss. That gave an extremely flat frequency response, but also a lot of energy storage. This compared, the old drivers were much quicker. They had some resonances, but you could get rid of that in the crossover. It was this run for flat response that gave a lot of modern drivers this dull, uninteresting sound. And you can also measure higher second and third harmonic distortion in some of them. If you compare the on-axis response between an old and new driver; you will see that the energy in the treble is far higher than in the new drivers. These so-called "modern" drivers often has a Qms of maybe 0.8 or 0.6. The old drivers had Qms values of maybe 5 to 7! We found that drivers with a very high mechanical Q sound more open, more clean and dynamic. And when you look at it, you find it is very simple, because they have less loss. The surround is easier to move, the spider is better constructed, they have better air flow, higher sensitivity. So a high mechanical Q is a very good indicator of energy storage behavior. This is one of our secrets. One of the many!
Well i used to think that there was no possible way for there to be a sound difference-but perhaps this is true.Im no golden ear!
Klippel.de article
Klippel.de article
Variance of t/s parameters with excursion
The total loss factor QTS considering all system resistances and the resonance frequency fS are important parameters for the final alignment of the loudspeaker system. Both parameters vary with the displacement if the motor and the suspension are nonlinear.
The instantaneous value fS(x) is proportional to the square root of stiffness KMS(x). Operating the driver A,B, C, D, F and G at xmax where Cmin=25% the resonance frequency is shifted one octave higher then at the rest position x=0.
An increase of the resonance frequency fs also leads to a higher mechanical loss factor QMS and has also an effect on the total loss factor QTS. However, the electrical damping usually dominates and variations of QTS(x) can be neglected if the motor is sufficiently linear.
Contrary, the electrical damping of the system will vanish with the squared force factor variation. For example, if the force factor variation goes down to Bmin= 25% the electrical loss factor QES(xmax) increases by factor 16 and the remaining mechanical damping will determine the total QTS. Operating driver F at xmax the total QTS is 10-times higher than at the rest position giving more acoustic output at fs. However, the generation of a distinct resonance peak and the shift of the resonance frequency by one octave are usually perceived as a spectral coloration of the sound (booming bass).
Certainly T/S parameters change with drive level, but how is this relevant to driver selection based on Qms, which was the original question?
Well i posted all that rubbish,because it seems to say that at high excursions Qms can become dominant-because the Vc is not being controlled by the Magnetic circuit (low bl state)
Cheers!
Dumax rates Xmag at 71% Bl, and at that point they claim there is about 10% Harmonic distortion due to that nonlinearity. So by the time you are moving far enough to get to the 25% Bl point, I would say that Qms is the least of your worries.
I was really just poking you to see if you understood what you had posted. 😉 Maybe we should all be buying woofers with a Qms of 0.2 so that when we factor in the doubling of Fs at high excursions and the neglectible contribution of Qes we get a reasonable Qts for our speaker design....
:devilr:
Luckily I prefaced my comment with
"For what it's worth"
And apparantly the comments I have read are worth nothing.\But I still hold to my concluding remark
"Listening to a driver is the final determining factor as figures can only tell you so much (but they are a good starting point)."
Madinoz- I agree with you. The sound is what matters. Whats important is the sound.
Also whats important,is to have listening experience of a very accurate system,to be a rule to compare others to.
What most of us here try to do,is find mathematical or physical reasons why a high Qms driver could sound better or worse-and if no reason is found,to continue with the idea that it probably doesnt.
Since I have a limited knowledge of physics (i.e an emperical understanding), then it would be pretty pointless for me to get involved in an in-depth expose on QMS, or any other technical aspect of loudspeakers.
Even people with a technical understanding still form pre-suppositions and then attempt to gather data to back up their opinions. They just sound a lot more convincing.
Could this thread continue as listing high qms woofers?
trying to find 5" to 15" high qms midrange/woofers.
The 5MR450-NDY-4, from PRV Audio
First an 5 incher midrange which has qms of 20.74
http://prvaudio.com/products/5mr450-ndy-4/
Spec sheet I saw lists it at around 15. Still pretty high. IME, high Qms in a midrange means a stiff cone (as well as suspension). That means lots of backwave reflections, requiring stuffing, which lowers the effective Qms.
What interests me is the higher power handling than a typical 5" (on par with 6" and some 8"). Of course, you always want more. You can do 1.5, now keep going guys, gimme a 5" with a 2" VC.....
BTW - love your avatar. Skip you, reverse it back to me, draw four, it's red, uno, and I'm out....
is found, to continue with the idea that it probably doesn't.
One arguement used goes something this :
Low Qms drivers have inevitably high losses in the suspension
and /or surround, the cone typically doesn't come into it at all.
High losses allow the possibility of hysteresis in the response.
Low losses (high Qms) reduces the effect of any hysteresis.
Hysteresis is assumed to be not a good thing in a driver.
rgds, sreten.
rgds, sreten.
Interesting.
I'd argue that Qms is fairly irrelevant in quantifying the performance of a driver. The Q-factors are only measured at Fs, where the cone is acting as a piston, resonating as a mass on a spring.
At that frequency, Qes dominates for >90% of drivers.
At any other frequency, all bets are off - we have no idea if the suspension/surround will have any frequency-dependent effects. The only data we're given describes behaviour at one frequency, and any inferences made about the performance at frequencies above resonance must be based on assumptions. As we know, assumptions are the mother of all mess-ups.
More important, IMO, would be distortion curves - bell-mode resonances and how they're damped are fairly obvious.
Chris
I guess I come at this question very differently, like the way you think intuitively about car and motorcycle suspensions.
Sure, you can weight down a cone to lower its resonance and that would have consequences for the mechanical Q... which you could then try to address electrically. But isn't that a dumb way to design?
It's the Corvette (heavy) versus Lotus (light) argument. It's a matter of reducing unsprung weight in your suspension by having in-board brakes.
Ben
