I am currently building the reference monitor loudspeaker with scan speak drives. I tested the crossover with the drivers connected before installing them in the wooden enclosure. The sound produced was very "thin" with very little low frequencies and very "cold". The same sound occured with or without the crossover connected to the woofers. I tried another woofer I had in hand (an old KEF Bextrene woofer) and this one played much better. Note that the bextrene woofer was designed for a closed enclosure without a bass reflex port. The reference monitor is a bass reflex port.
So the question are:
1)Will the sound of my scan speak drives change so much when I will put them in the enclosure? Does the enclosure magnify the low frequencies so much?
2) I have used an enclosure with thicker panels. Does this mean that I have to adjust the port hole lenght? If yes then how?
Thank you
George
Athens
Thank you
George
Athens
yes.. the enclosure will make it sound how it should... I have no idea what your second question is.. lol
I think he is saying that he used thicker cabinet walls then the plans called for. Assuming his internal volume was the same, if he surface mounts the port, the inside tube will be 3/4" farther out of the cabinet then before. Not sure what effect that will have though, maybe slightly increasing the cabinet volume including the slug of air in the port?
SkinnyBoy thank you for your reply.
About my second question:
The initial box enclosure is made out of 25mm thick side and back panels. I have used panels that are a bit more thick (32mm). The port lenght is 14.5 cm long in the initial design with 25 mm thick panels. Now that I have 32 mm thick panels do I have to change the lenght of the port from 14.5 to something else?
Thank you
George
Thank you
George
George,
You do not need to change the port length if you maintained the same internal volume of air when you increased the wall thickness.
If you kept the same external diamensions when increasing wall thickness then the amount of air in the box will be less so it might be necessary to retune the port. To recalculate the new port length, you need to specifiy the original box volume and tuning frequency as well as the Qts of the woofer.
Nice one,
David.
Nice one,
David.
