I am searching for a pair of either 6.5" or 8" (4ohm) replacement woofers for a JBL STADIUM speaker.
I would like to keep the price under $100 for the pair. Any recommendations?
Stadium Speaker specs as follows:
Frequency response (-3 dB): 36 to 20000 Hz
Maximum recommended amplifier power: 225 W
Power handling: 110 W continuous, 440 W peak
Sensitivity (2.83 V / 1m): 91 dB
Nominal impedance: 8 ohms
Crossover frequency: 300 Hz, 4000 Hz
Low-frequency transducer: Dual 8-inch (200-millimeter) PolyPlas, shielded
Midrange transducer: 4-inch (100-millimeter) PolyPlas, shielded
High-frequency transducer: 0.75-inch (19-millimeter) titanium-laminate dome, shielded; EOS waveguide
Dimensions: 9.875 x 40.25 x 15.75 inches / 251 x 1022 x 400 millimeters (WxHxD)
