Woodwork Safety
Joined 2016
Ear defenders CHECK!
Eye protection CHECK!
Gloves CHECK!
Work boots CHECK!
No loose fitting clothing CHECK!
Stable work surface CHECK?
Gloves and rotating power tools do not mix. The fabric winds round the shaft and pulls the hand and arm into the cutting edges remorselessly.
Don't wear gloves when operating a lathe/drill/router/rotary saw(*). Long sleeves need to be turned up, and ties are verboten.
However suits of armor are fine!
(*) Well guarded rotary saws may be an exception to the rule, but why would you need gloves anyway?
