wont turn on 2, linear power 4753 iq.
this is for a linear power 4753 iq. i wanted to keep it separate from the 2.2 thread.. so i did the same readings. only when i touch the +b lead i get a small spark. here are the pwm readings. it is a:
SG3526N chip
pin 1: 4.98 volts
pin 2: 0.002 volts
pin 3: 4.20 volts
pin 4: 4.65 volts
pin 5: 4.98 volts
pin 6: 0.002 volts
pin 7: 0.002 volts
pin 8: 4.95 volts
pin 9: 3.57 volts
pin 10: 1.876 volts
pin 11: 0.002 volts
pin 12: 4.31 volts
pin 13: 4.69 volts
pin 14: 10.78 volts
pin 15: 0.003 volts
pin 16: 4.68 volts
pin 17: 10.78 volts
pin 18: 4.98 volts
it is possible that hte 10.78 volt readings are because the power source i was using was possibly losing power.
thanks guys i appreciate any and all comments.
Re: THANKS BOOM
IMPALAMAN1 said:
MIGHT YOU HAVE ANY LP STUFF FORSALE?
No. I currently running an LP 2002 thru an AudioControl 2XS (so I can bridge it) to a JL Audio Microsub 8.2 (2X8" 8W1's), and a LP 4753IQ to a set of JL Audio XR 650 CSi's.
They have some decent Linear Power amps on eBay this week. I bought my 4753IQ off ebay.
