Here is the specs of the iron I am using.
EDCOR - XPWR104-120
I built the power supply like the mila and have it in a separate enclosure. It connects via a 6pin cable: B+, B-, Chassis GND, fil1, fil2, 48volt.
I am wondering based off of current specs for the above transformer can I run 2 channels of 6SN7 pre at the same time?????
This will be a first for me so I need your input folks.
By the way, the one channel with this power supply sounds incredible. Zero noise, and big fat tone depending on which 6SN7 is in the socket!!!!
Thanks!
EDCOR - XPWR104-120
Thanks!
