It's the moons gravitational pull on the earths dense core moving it around causing friction and so to heat up and melt or stay molten!
Don't think so....entire planet was originally molten after initial accretion due to kinetic energy of infalling bodies & has been cooling since. During the early stages of cooling the heavier elements tended to sink toward the center adding significant thermal energy as the potential energy was converted to heat by the friction of their passage to the core. The cooling is also offset by ongoing heat generation due to radioactive decay. Eventually earth will cool and solidify to a uniform low temperature. Tidal effects of moon's gravity are far too feeble to maintain the core temperature or add much energy to the mix.
Shouldn't think too much about the distant future !
" Go for it now. The future is promised to no one. "
Wayne Dyer
Wayne Dyer
A good pilot breaks ground and flies into the wind.
Maybe the core is molten because of all the waste energy from the alien bases? Somebody had to say it!
"Youth is wasted on the young"
"Life is a short warm moment, death is a long cold rest" ( Pink Floyd )
How do you know you are REALLY growing old ?
When you start discovering 'new' significant things and later realise you have already discovered or understood them long ago !
Joined 2009
You learn more and more about less and less. eventually you reach a point when you know everything about nothing. thats when you are called an expert.
I realy like that one...😀
I was told the other day after explaining how to find a fault on an old tube amp
You seem to be an expert on old technology...😀
I guess Your post is very apt..😀
M. Gregg
Quote
"To live is the rarest thing in the world. Most people exist, that is all.”
M. Gregg
M. Gregg
vivir es amar,
amar es suprir,
suprir es morir,
moris es descansar........
to live is to love,
to love is to suffer,
to suffer is to die,
to die is to rest.......
amar es suprir,
suprir es morir,
to live is to love,
Just seen this one..
If you don't know where you are going, any road will get you there..
M. Gregg
M. Gregg
Yes,
But its turtles all the way down..
_________________________________________________________
If you don't cast pearls before swine..what lights up the darkness?
Here is a moment of clarity from John Wayne..LOL
“Life's hard. It's even harder when you're stupid.”
M. Gregg
M. Gregg
- Member Areas
- The Lounge
- Wonderful short quotes on Life.
