I have a new dac board on the way.
It is a dual pcm1794 design with a wm8805 transceiver chip.
I want to add more digital inputs to the wm8805 (which is capable of 8) as the dac only has 1 spdif/Rca , 1 optical and a usb xmos input.
I need help in how to connect the new connections into the wm8805.
I would like to have 6 spdif connections including the original one optical and one AES input.
I also would like to install a screen in the front panel of the case to view input numbers and sample rate with a remote control to change inputs.
Also if possible I would like to add an upsampling board into the mix.
Can any one help.
Can any one help.
