WM8804, no DOUT
Guys
Last few weeks I have tried to design a SPDIF receiver with DAC. Yesterday I have build it finally. Sadly it don't work. The power supply is OK and the signals at the pin "BCLK, LRCLK and MCLK" seems to be there. But there's nothing coming out the DOUT line.
I use the chip in hardware mode. I have used a digital output of a old CD player to test it.
Is there someone who can check my schematic if there is an configuration error?
Many thanks!
Thank you for the tip!
I have tied the CSB pin to the supply with a 10K resistor. Sadly my scope is broken so I only can listen. It now seems to do something. It's humming at the output . . .
A led does not blink when connected to the pin. A 12mHz crystal is connected.
