I have a cheap Soundstorm F4.400 amp (4 channel, non bridgeable, 2 ohm capable).
I want to use it to drive two small drivers in stereo on channels 1 and 2, and to use channels 3 and 4 to power one small 4 ohm subwoofer. I realize that bridging is not going to work like on most higher end amplifiers. What if I combine the positive signal on the left and right and feed them to the sub, therefore giving each channel a 2 ohm load (which the amplifier is capable of doing apparently)? Would the amp survive that and give me mono, while keeping stereo on the other two channels?
Regards,
Alex
Regards,
Alex
