Well it sound like series to me. That was how they should be if you are trying to increase your impedance and go easy on your amp. In your first thread you say you have 3 of these woofers. I am assuming the wiring continues in series?
What do you mean you keep blowing your amp? It is bridged (parallel). Are you sure it is a bridgeable amp?
I think the first thing I would try is to separate the amp leads and run one set to each of two woofers, with the third woofer left out of the equation for now, as see what happens.
- Subwoofers
- wiring for less load on amp
