Wiring Balanced Volume Pots?
Thanks for the info. I'm having the same issue and it has been explained very well here. Just one last question : Is it safe to completely remove the series resistor ? if I don't put any series resistor on + and - (5K on the example above), there will be no gain loss right ?
Hi Andrew thank you for advise and help. My system sounds great now. May I ask, between a 10k pot and a 100k pot is there a huge difference ? Especially so when the new CD player I am getting have a +4dB strength. Thank you in advance for your advice.?
So if i use 1 100k pot with 2 5k series resistor,
the gain would be as follows:
Amp input Imp = 200K
parallel resistance would be 1/100k +1/200K=1/0.015=66.7K
Max Resistance=5+5+66.7K=76.7K
gain therefore=66.7/76.7=0.87x3=-2.6
Really green diyer here, so please don't bash .. : )
Read the posts, understood the wiring and the math, even made up a simple XL sheet to do the calculations for me (given the amp Zin and pot impedance, use goal seek to find resistor values, to go for the 0.87 gain = -1.2 dB).
Then stumbled on this X3 multiplier, that ruins the perfect -1.2 dB in hschaser's math. Why is that for? Wasn't there in AndrewT's brilliant explanatory post No 16...
