I would like to wire my DIY amp project for direct in as in full on via 100k resistors & switch to 2-100k mono pots when I feel the need useing a DPDT switch. I just am haveing a severe brain stop moment & can't see a way to wire it correctly for this...any help would be appreciated.
Joe
Joe
Hi
You want the switch to bypass the volume control? In the first diagram below, the pot still loads the input, even when not used.
If you want to totally disconnect the pot, you'll need a 4 pole 2-way switch (or a separate DPDT for each channel). Second diagram shows this for one channel.
Cheers - Godfrey
Cheers - Godfrey
