wires of output transformer are too thin!
http://www.alphawire.com/pages/383.cfm
According to a quick Googling of AWG tables, hair-fine 30 Gauge will carry ~2 Amperes. Derate that by 50% for bundled wires - so say 1 Amp. The plate current of a really cookin' 300B amp is 75 mA = 0.075A. So that's quite a safety margin.
As for the difference in gauge between primary and secondary:
Without going to the bookshelf, the voltage and current are doing inverse things across the windings. An output transformer is a step-down device - say 5000:8, . But in this context, "step down" is referring to voltage, not current. Current does the inverse - it's magnified, so to speak.
So small fluctuations in that 0.075A current is going to be turned into large current fluctuations in the secondary. Cone speakers, being horribly ineffecient devices (on the order of less than 5% ?) need that current to move.
All in all, it sounds as though you have a properly designed transformer.
Uhhhhhhhhhhhhhhhhhh.........
Holy cr@p!
Like using your OPTs as expensive fuses, eh?
Come on... even not-so- common sense tells you no ordinary OPT will handle half that without melting. 1 or 2A will melt the copper wire itself, fusing it (literally, using the 30ga wire as a fuse).
Tim
I'm going to stick my head out here and exclaim that the derating factor which is present on that website is determined only for wires which are bundled/insulated for use in interconnecting purposes and not coil winding for use in situations where eddy currents require consideration.
If you take a look at an ordinary wire which you use inside your amplifier (and any other project) you will notice that there is not just one wire connecting point A to point B, if there were, it'd be incredibly hard to solder one to a point (within reason) and to bend the wire around a corner or whatnot, I think this is what that website is mainly used for.
I personally have no knowledge of proper cable ratings for transformers or interconnection wires but what I just said "sounds about right" to me anyway.
If you can get the jist of it =). :xeye:
