Ive always wanted to build myself a wireless guitar system so i can move about more while im playing, and have just noticed an IC from www.maxim-ic.com - the max2606
details found here http://www.maxim-ic.com/appnotes.cfm/appnote_number/1869
it looks pretty straight foward! im quite keen to modify the front end slightly to match a guitar, although it might need a preamp before this too as it is expecting a line input level. wouldnt hurt to maximise the SNR anyway..
but the whole thing could be powered by a 9V or a few 1.5V batteries and might even be small enough to put inside the guitar? if not then i think commercial designs have a small box that clips onto the strap..
anyway, im keen to have a crack at this project to see if any good results are possible. Anyone else keen?
only problem at this stage is the chip is tiny, which makes it a pain to solder to, but its only 6 pins..
schematic:
schematic:
the reciever?
-i was just going to use a standalone digital reciever with a lineout..
ive ordered some samples of the IC, so when they get here i'll start immeadiatly..
although i cant find an inductor anywhere right now, ah one will turn up..
Lookon the Maxim data sheet, it will either spec that the inductor is so many turns around some sized form (we usually just use a resistor as a form), or they will be using a commercial product.
Hi Optical
Might be simpler to buy a "bug transmitter" kit such as Jaycar Electronics KE-4711 (AUD$11.50) or KJ-8570 (AUD$19.95). They interface directly to an electret microphone so may have the sensitivity you need.
They have branches in Auckland, Christchurch, Hamilton & Wellington or you can mail order.
Cheers
Rob
Cheers
Rob
well those chips turned up, but they were so tiny they were unsolderable... ~3mm x 2mm... that will teach me for not checking the IC package..
Instead i have ordered some FM transmitter kits and modules from www.oatleyelectronics.com
They have locked frequencies and are quite powerful. I have ordered one straight transmitter module, and another kit with a preamp that also includes the module..
so hopefully they will turn up soon and i can try it out!
it should be good, it runs from a variety of voltages so a 9V should do for the transmitter and the preamp.
Only problem i can foresee is the ariel is quite long.. im not sure where i would put it? maybe stitch it to the strap or something..
here are links to the specific transmitter ive ordered.
http://www.oatleyelectronics.com/txandrx.html#FMOD1
http://www.oatleyelectronics.com/kits/k222.html
Another thought, since they are stereo i was planning on simply summing the inputs and outputs.. But what about making a balanced transmitter? By using a balanced signal it may help decrease any negative effects from the transmission?
what do you think?
something like this http://sound.westhost.com/project51.htm or an INA217
what do you think?
you may still want to try those chips, lol it looks more tricky than it is... First put tiny but if solder on traces on pcb, just enough to turn it solder colour... then position IC....
Now put one huge solder drop on top of the pins and let it melt covering all the pins on one side.
Now while its melted press down on the IC to form capilary suction between the pins and pcb.
Next use desolder pump to quickly suck the excess solder away, it should leave only the bits traped by capilary action between pins and pcb. any small leftovers (if any) can be removed with desodler wick.
well i dont have a pcb to even try that technique on, and im not going to make one so they are def. a no go..
ive been looking into the expensive commercial wireless models to get an idea for the tricks they use and apparently the drift you get with an unlocked transmitters can often ruin the whole thing..
the ones im getting have locked oscillators. i just need to work out whether summing the channels or sending a balanced signal would be best..
hopefully they will arrive soon and i'll suss it out.
Right, my FM transmitters have turned up, as soon as i can be bothered i'll wire them up and test out how well it works..
I'll post a new thread with the results soon!
I don't know if it is even possible but if you ever figure out how to build one where the input level to the amplifier will never vary I might consider using one but so far nobody has and that's why I don't.
Surely he does not mean in the FM broadcast band. I think he just means frequency modulated transmission. Right? There are all kinds of FM transmissions all over the place outside of the FM broadcast band. Most are above it.
Since you're dealing with the FM band, aren't you worried about outside interference?
- Live Sound
- Instruments and Amps
- wireless guitar project
