I've inputted 2 very similar drivers into WinISD...
The Faitalpro 4FE35 (ceramic magnet version) and 4FE32 (neo magnet version) to determine a closed box alignment.
FaitalPRO | LF Loudspeakers | 4FE32
FaitalPRO | LF Loudspeakers | 4FE35
*yes I'm evaluating 16R drivers..two per box parallel.....
The T-S parameters for both of these drivers are very close (as expected) with the exception of Qts, Qes and BL product.
When I input the 4FE32 (neo mag version) I get multiple choices for system Qtc ranging from .9 equal ripple resp to 1.5 equal ripple.
Inputting the 4FE35 (std magnet) the only alignments offered are 1.2 and 1.5 equal ripple.....I've faked the Qts, Qes and BL T-S values for the 4FE35, but WinISD still only allows two alignments Qtc 1.2 and 1.5.....
I thought that driver Qts was a big factor in possible alignments, but now I'm confused.....
