AndrewT said:I recently changed my browser to Firefox.
............. defaults to details
Hi Netlist,Netlist said:I have to conclude that it is impossible to make the 'Details' view sticky in Common Controls.
I say again, my XP defaults to details every time.
jb74 said:Netlist -
Its interesting to experiment.
You said earlier:
In Vista, this problem is fixed.
Maybe Vista has a same named file to look into ?
Some substitutes will work - for instance, Deltree from 98 will
work within Xp (at a Command Prompt)
The common controls are in windows shared libraries.... Not generally the kind of thing you can move between operating system
Andrew,
I wished Firefox would do the trick here. I'm glad it works for you but it's hard to believe that Firefox would alter comdlg32.dll or replace it with a 'Firefox version'.
Looking at what MultiEnhancer does, it appears that only comdlg32.dll is responsible, located in \system32 and in \system32\dllcache.
I agree with Dan, but I'll definitely try to replace the Dutch dll with the English version. Or, if someone knows of a good dll editor, I can diy in the heart of the system file.
/Hugo
/Hugo
AndrewT -
Some who have viewed this thread (myself for one) thought that
the solution wanted was when using explorer (explorer.exe)
To see the real subject problem, right-click on your desktop and create a new text document. (New Text Document.txt)
Open that blank text document, then click on file>open at the top left of that text document window.
A new window opens with the word "OPEN" at its top left -
if your Xp works like mine, the view in that new window will be
in the "List" format. (the default format courtesy of MS)
There is a little box at the top right of that new window where the
format can be changed manually - but only AFTER that window has
been opened each time.
Netlist said:it's hard to believe that Firefox would alter comdlg32.dll or replace it with a 'Firefox version'.
Not sure about Firefox in this instance but replacing system files for added functionality is standard fare in windows. It is also one of windows greatest flaws, and the reason the automatic system file checker came to be.
AudioFreak said:The common controls are in windows shared libraries.... Not generally the kind of thing you can move between operating system
Who's willing to try? Can anyone get comdlg32.dll and commdlg.dll from vista for an XP user?
Here you go......
http://s000.tinyupload.com/?file_id=05014460930971870200
Tried it and stopped. The files have a Visual C runtime procedure dependency. The dependency tree may go further. I don't have the time right now.
Whoever may try it, get the latest msvcrt.dll and have an alternate method of file system access, as the UI is dependent on the common dialog files and they will take out safe mode.
- General Interest
- Everything Else
- Windows XP tweak
