No sorry, I meant could a problematic bridge rectifier cause the low pass problem? I am basically getting a full spectrum signal through with the low pass working in parallel by the sound of it. It doesn't even sound like a sub at the moment, just a bassy normal speaker.
Am I looking for excess heat, or expecting something in the signal to change?
Maybe check the supply voltage(s) first to make sure that's OK.No sorry, I meant could a problematic bridge rectifier cause the low pass problem? I am basically getting a full spectrum signal through with the low pass working in parallel by the sound of it. It doesn't even sound like a sub at the moment, just a bassy normal speaker.
Jan
