Ok all , sorry for delayed response was away out of country.
Just took up the measurements.
Fs=41 Hz !!!!!!
Qts=0.55
Qms=7.0
Qes=0.59
I put it in a sealed box of Vb=82 litre and Fb=44.5 Hz giving VAS=14.8 litres
Now 14.8 L is small Vas, the driver sensitivity around 88. WinISD gave me 1.44 cubic feet with 30 Hz tunning ??????for c4.sc4 chebyschev...for most output in 30-40 hz range which is good enough for music. for below 30 Hz i have to go extended bass shelf. ??
BUT the wison watch dog is actually around 4.8 cubic feet external. with bracing, port and separate box for amp i expect it to be around 3 cu feet or around 140 L. BUT winISD gave me 1.44 cubic feet ??? with 4,6 inch tube going 32 inch long ????
HELP HERE please
Fs=41 Hz !!!!!!
Qts=0.55
Qms=7.0
Qes=0.59
HELP HERE please
You want the Fs to double, so shrink that box down much smaller, if you want a meaningful Vas measurement. That said, it does seem like a tiny Vas.
Fs=41 Hz !!!!!!
Qts=0.55
Qms=7.0
Qes=0.59
HELP HERE please
no i never said i wanted Fs to double ??? i wanted it to be low but i cannot understand how there is so much discrepancy in box volume.
To get an accurate Vas measurement, you want the Fb to be double or more times Fs. Your test box is too big to get a good grip on the Vas.
Ok i got the point, then i think the vas calculation is wrong. can i use weight method. any brief link please. would 100 g do.
