http://cgi.ebay.com/PFO-MH-250W-HQI...ryZ46314QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
its cheap and easy to use but it doesnt say how bright in ansi or lumens
I was also think of use a different setup how about a dukane 4003 stripped of light source and build a projecotr of of that the bulbs are cheap and the light is rated at 4000 lumens at
FXL-5
410W 82V Base Type: GY5.3 Avg Life:200hrs Type of Use: OHP Special Description: Dichroic Reflector
Availability: In Stock
$8.35
the designs wanting to use are http://diyprojectorcompany.com/designs/index.htm
ill doing measuring and other stuff to find one that best suits me
but on problem i ran into is that i was going to use my sharp qa 2500 in this project, i was think of not stripping it because it is already made to be used on an overhead, I just trying to take a safe route so i dont screw up my panel
FXL-5
$8.35
not useful
I think it doesn't say how bright it is because it does not include a lamp! It says it can use up to a 250 Watt, but that's all!
Since ballasts tend to work with one specific type of lamp, I wonder if it even includes a ballast?
So all you get is a reflector that is designed for an aquarium, not for a projector. BTW, beware of "reef lamps": They are usually 10,000 K color which is much too blue for projection. You need 5000 to 6000 K.
Just for interest i'm using a 10k 400w metal halide lamp and the picture looks great. The colours look a tiny bit dark but its shining onto a painted wall which doesn't help. Once i've adjusted the gamma in windows there's a very even balance. I'll get some shots up soon - just got pefect corner to corner focus after a bit of tweeking.
