This will be my first project, and any advice is welcomed - the Cyburgs-Needle with Visaton FRS 8:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=29321&highlight=
The first question would be: is there an improvment if I add a tweeter to this design? If yes, any tweeters that you could recommend, from Visaton or Monacor? What cut-off frequency?
The two Needles will be the satellite speakers, and I will use a subwoofer:
http://www.visaton.com/english/artikel/art_543_6_23.html
The cut-off frequency of the sub will be adjustable, to a max of 110Hz.
Suggestions??
Thank you.
Suggestions??
Thank you.
Ruben19 said:This will be my first project, and any advice is welcomed - the Cyburgs-Needle with Visaton FRS 8:
The Visaton FRS 8 will not need a tweeter in the first place. But if you want a bit more clarity and less beaming in the highs then have a look at the Vox 80 and the Nano Sat by Visaton and their CP13 tweeter. Perhaps you could do something equivalent for the Needle.
Here is another combination ...
http://www.visaton.de/vb/showthread.php?s=&threadid=12013
Look in that link for posting #7 from the top. The diagrams will tell you all. Dimensions are under the x-over diagram.
