If you want to use the first double-triode as a diff-amp, you should plan for a cathode CCS, which will need a negative rail of at least some 6-8V, preferably 15-20.
You will need a bypass cap for the The EL156 cathode resistor.
If you do not have a very high output pre-amp, the input sensitivity might not be sufficient, especially if you plan some 6-10dB global feedback.
SveinB.
SveinB.
Thanks for your comment! Maybe i should use a ECC83 instead ECC88 to have more gain. And the Bypass cap of course!If you want to use the first double-triode as a diff-amp, you should plan for a cathode CCS, which will need a negative rail of at least some 6-8V, preferably 15-20.
SveinB.
Silvino
