I am looking at making some new rear speakers using these two will they go together all right
woofer a 5.5" vifa this is all I can find on it
110Wmax
Coil 25mmØ
Mag 240g 75mmØ
Zo 8 ohm (5.5ohm dc)
Fs 52Hz
Sens’ 86dB
Qms 2.86
Qes 0.50
Qts 0.43
Vas 12L
Code TC14SG-68-08
the tweeter vifa also
Coil 20mmØ
Mag 105g 70mmØ
Zo 6W (4.2ohm dc)
Fs 1400Hz
Sens’ 90dB
Qms 3.10
Qes 1.76
Qts 1.12
Code TC20TD-05-06
can any one suggest a good xo point as well thanks guys
110Wmax
Coil 25mmØ
Mag 240g 75mmØ
Fs 52Hz
Sens’ 86dB
Qms 2.86
Qes 0.50
Qts 0.43
Vas 12L
Code TC14SG-68-08
Coil 20mmØ
Mag 105g 70mmØ
Zo 6W (4.2ohm dc)
Fs 1400Hz
Sens’ 90dB
Qms 3.10
Qes 1.76
Qts 1.12
Code TC20TD-05-06
You could probably mate these up just fine. Crossovers are a tricky and individual thing, but my first shot at it would be something like an acoustic Linkwitz-Reilly 4th order at about 3 kHz. This puts you an octave above tweeter resonance and at a point where the woofer still has OK dispersion.
